I have narrowed down my pick of receivers to the following Marantz sr4500 or the Harman Kardon avr235 I am running a small Ascend set-up. Any suggestions on either of these two?
I would go with the Marantz, the Ascend's are speakers that most people put with a "bright" receiver and the H/K is the opposite of a "bright" receiver.
iluvbeer
So you would think the Marantz is a more bright receiver?
iluvbeer
So you think the Marantz is a more bright receiver?
I want to buy a new receiver, but im not sure if it will work on my t.v. I do not think it will work because my vcr is what i use to change channels and i am afraid that i will have to take that out to put the receiver in. what should i do?
I always thought the Ascends were pretty neutral, not bright. I think either reciever would work fine with the Ascends. Ascend sells H/K on thier site so that probably is the best match.
