I have Arcam Alpha 9p Power Amp, and I need a pre-amp with two sets of outputs for bi-amping in future. Please recommend models you have experienced that could go well with Arcam. thanks
There are loads to choose from. If you wanted to biamp immediately, you could buy an Arcam A90 and biamp with the P9 which would be a good partnering. Arcam also make the FMJ C30 preamp which is excellent.
The Cyrus Pre-X has three preouts so you could triamp with that model. It's a cooler presentation which is probably a good thing since the Arcams, particularly the older models, are quite warm.
That's just a couple in a long list that could be worth your while looking at.
When I try to run cassette tape to my philips stand alone CD burner I get a very low signal, Not enuff to move the meter on the burner! When I use a turn table I have no problem. I run the gear into a 10 band EQ & even with that I can't boost the tape singnall enuff to burn a disc! My guess is I need to run some kinda amp between the tape & CD burner. Any ideas on what I need. Jinamann
