Like
Vibrapods under your Amp
Username: Moroblue06
I tried using 4 size 3 vibrapods under my amp (roksan caspian power amp) and didnt like the effect (it lost a tint of excitement). has anyone experienced the same?
it seems that pods only benefit cd players.
would love to hear from your experiences.
cheers to all!
J. Vigne
You can try different numbers and different positions with the pods. Try three with one under the power supply transformer. If that doesn't work, try spikes or cones under the amp. They will do a good job of sinking vibration into a surface such as a dedicated amp stand. You should also damp the top plate. Try a diver's weight ( obtained at a skin diver's shop). Try it in different positions on the top. If it sems to help you can SuperGlue three small ball bearings on the bottom of the weight to help mass load it to the amp. Some people use a magnetic material to absorb stray magnetic fields. This was the basis for the VPI brick. An easy substitute for this is a box (a few Lbs.)of small screws or nails. Try it and if it helps the cosmetics are up to you.
Facebook
Directory
