Like
Anybody can tell my which of them better - nad c352 or c372?
Username: Amir
Post Number: 17
anybody can tell my which of them better - nad c352 or c372?
nout
The C372 has more power for sure, but they seem to sound identical, according to almost everyone who has auditioned both, including me.
What is your room size? You can imagine that more power will mean it will have a better control and will not distort when playing really loud. There's the difference.
Steve764
Amir,
IMHO it is true that there is litte difference re. sound. But again, it all depends on your setup (speakers and room size) and the level at which your will listen your music to.
There is however a little difference, it is a technical detail but it may be important to you. The C352 does NOT have A/B speaker outputs. Whereas the C372 has A/B speaker outputs and the ability of remote switching.
Username: Amir
Post Number: 18
Hello to everyone.
if i will buy the NAD c352, can i connect to this a sub wofeer ?
in c372 i know that i can connect a sub woofer into the speaker B connections , but in c352 there isn't such connections!
my loud speaker is designed to work with sub woofer,
i have JBL S36, and i know that c372 is able to producing a lot of bass , and maybe, if i will buy the c372, so i will have enough bass without the sub woofer!?
Facebook
Shop Related Deals
Directory
