New member Username: Bs_fanaticPost Number: 1 Registered: Oct-04 | hey guys, what up i am looking for some speakers that do not necessarily have a limit, so basically i would like them to be so loud that i would want to turn them down! i dont care about the size or the price, if anyone has some good suggestions for what i can buy thanks. i will mainly use it to listen to music. duh. the speakers need to be selling in the us, because i know there are some exellent ones in Japan! by:Jonathan Kirk |
New member Username: Es_eye_em_ow_enPost Number: 5 Registered: Sep-04 | cerwin vega have some very sensitive speakers wich im sure will be loud, check thier site www.cerwinvega.com |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 128 Registered: Feb-04 | As loud as can be? Sounds like a case for Klipsch's heritage line Klipschorns: 104 db at 1W and 1m. http://www.klipsch.com/product/product.aspx?cid=2 |
J. Vigne Unregistered guest | No doubt, the Klipschorn is the only speaker to buy. I have delivered many pairs and had one fellow who, after the speakers were set up, he walked across the street to find out if they were loud enough. Cornerhorns do require two solid corners, though, if you can provide that look for the next step down; the Belle or the LaScalla. |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 638 Registered: Dec-03 | Jonathan: What kind of amp do you have to drive these speakers? It makes a difference. |
