hey has anyone ever used a dj amp? i noticed that they all have rca inputs, but they have "banana plug" outputs. does anyone know if you can just connect speaker wire straight into these outputs? or will i need some kind of converter? someone please help. thanks.
i havent tried anything yet. i was wondering if i can connect regular speaker wire from the "banana plug" output straight to the voice coils of my speakers. is this possible? or do i need some sort of convertor?
Banana plugs are just a convenience connector, specially if you are pulling them in and out of the amplifier constantly. You should be able to connect the speaker wires directly to them.
