Bronze Member Username: SinkdrainPost Number: 13 Registered: Aug-04 | Ok, I was looking at the H/K avr330 but now my budget has been slightly slashed. The avr230 is now in the $300-400 (street price). I see there is a Pioneer VSX-1014TX out there for the same price, feature packed. Have any of you heard these two receivers. Now that I am in the $300-400 range I am worried that their are better choices than the H/K for my Athena speakers. |
Silver Member Username: BleustarPensacola, Florida Post Number: 121 Registered: Jul-04 | Gererally speaking the entire AVR line from HK(leave out the AVR7300) sounds the same. The feature set from the AVR230 to 330 will be the only "real" difference. |
Silver Member Username: Rh1Post Number: 179 Registered: Jun-04 | Both of those receivers are well worth their respective price. I think you will do fine with either one. I have not heard the 1014tx, but i have heard the 914 model and it was quite pleasing for a low budget receiver. I think it's certainly better than Onkyo, Yamaha, and Sony's receivers in this price range. I would say that features would be the deciding factor in those receivers you mentioned with a slight edge to the 1014tx IMO |
Silver Member Username: Rh1Post Number: 180 Registered: Jun-04 | Have you tried finding the AVR 330 online? Here's one for $369 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39794%26item%3D5724052220 %26 |
