New member Username: Schmittie120Post Number: 1 Registered: Dec-06 | hey i was just wondering if there is any way that i can hook up 5.1 speakers to my macbook pro? sprry if this question is a repeat but i could not find a question like mine......thank you for all your help |
Silver Member Username: Arande2400dB could probably d..., 4000 isnt ev... 100,000dB FU... Post Number: 545 Registered: Dec-06 | All you need to do is buy an Audigy zp sound card or something. Here's the link to the forum where it's discussed. https://www.ecoustics.com/electronics/forum/computers/307386.html Easy enough. |
New member Username: Schmittie120Post Number: 2 Registered: Dec-06 | but isn't that sound card for windows.......i am not sure but if i can use it for Mac OSX |
Silver Member Username: Arande2400dB could probably d..., 4000 isnt ev... 100,000dB FU... Post Number: 554 Registered: Dec-06 | Oh that's right silly me. Well you can ask Jennifer, I don't know if she'd know. |
Bronze Member Username: PeterbiltMy Best Friend :, 7.62-mm SVD ... JenCon-Team. Post Number: 11 Registered: Dec-06 | http://www.sweetwater.com/store/category/c709 |
New member Username: P4sPost Number: 1 Registered: Jun-07 | try this - Altec Lansing FX5051 they go via USB and theyre 5.1 with isobaric woofers |
