Polyfil did wonders
ThatGuyYouKnow
Well lastnight I went to walmart around 1am and bought 2lbs of polyfil and got home stuffed each chamber(1.25cuft) with 1lb of it and stampled it on the inside, hooked it back up, and was amazed with the results best $12 ever spent for the system.
Username: Invain
Michigan United States
Post Number: 101
Hey, what exactly did it do? Did it make the bass tighter and louder? I am heavily thinking about putting some old pillowstuffing stuff I have which is pretty much polyfill in my sub box, since the box is a teeny bit too small. Can you tell me what all it changed in meens of sound?
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 85
Yeah, I would like to know also. My box is too small for my subs.
Username: Jayj
Louisiana USA
Post Number: 488
All polyfill does is slow down the sound waves so you will have better SQ and alittle more SPL. If your box is only like .2 or so off then it will help the subs proformance.
Username: Invain
Post Number: 112
Awsome, my box is liek exactly .2 cu. ft. off.
Username: Jayj
Louisiana USA
Post Number: 490
Well then you should get a pretty good benefit from it. Just pick up a pillow or 2 and stuff it in. You will need about 1pound per cubic ft.
Oh be sure to cut the pillow and take the filling out lol.
Username: Invain
Post Number: 114
Hey JayJ, by the way. My box is 2.28 cu. ft. Would I use 2 lbs of poly fill then? 1 pound for each fubic foot?
Username: Invain
Post Number: 115
Ok, your last post wasn't there when I wrote my last one so don't think I can't read. I just have a big bag of the crap so I'll weigh out 2 lbs of it.
Username: Jayj
Louisiana USA
Post Number: 492
I would do 2pounds are maybe just a pinch over 2lb.
Username: Invain
Post Number: 116
ok
Username: Caraudiofng
Houston, TX
Post Number: 249
Is it the same for sealed....1 lb per Cu ft?
Username: Audiobahn_man
Freakmont, MI
Post Number: 33
does it work for ported boxes??
You ONLY use polyfill in sealed boxes. NOT ported
Username: Stebbie
Corpus christi, Texas Usa
what if your off about .5
my chevy ext cab wont allow a bigger box and its built for 12's
