Wiring quality?
Username: Bandit8623
Rochester, Minnesota Us
Post Number: 17
will rewiring my wires from my head unit to the rest of my speakers and amps help much for quality sound or is the factory wiring going to be good enough. thanks for any input
It depends if the speakers are wired to the right impedance to give optimum output... it wouldn't hurt to check and see. But otherwise it shouldn't matter.
