Ported boxes....
The recommended ported box for my sub is 2.5 cu ft, tuned to 35 hz. My question is does 2.5 cu ft include the area of the port, or is it 2.5 cu ft without the port?
Username: Sploosh56
Post Number: 316
it's 2.5 cuft without the port area and the displacement of your subwoofer.
Username: Jonathan_f
GA USA
Post Number: 937
Yep. You consider ports and sub displacement as solid objects when building a ported box. A good 2.5 cu ft. 35 hz box is on www.reaudio.com, go to tech, then enclosures, it will give dimensions for a 2.5 cu ft. box tuned to 35 hz, it's for the 12" X.X.X. sub. It'll sound really good because of the slot vent, and get really loud.
