What should i put in it
I have a 94 blazer 4-door and want to put a hell of a system in it and would like to have some ideas of what other people would put in it to make it thump?
Username: Sploosh56
Post Number: 313
2 15" Adire Brahmams in a ported box tuned to 31hz each with it's own JL 1000/1 amp. :-) That would pound and sound awesome. Make sure you get an alternator that can handle all of this power.
I was looking at Delco-Remy alternators, which one would be a good choice to put on my blazer to make sure I have enough power
Take a look http://www.alternatorparts.com/cs130d_cs144_trk_suv_upgrade.htm
Username: Jonathan_f
GA USA
Post Number: 914
200A, but the 1000/1 amps could still draw more than that alternator could put out, I don't think you'll be using the amps near their full potential, anyway. The only way you'll get an alternator that'll give the amps what they want at full draw would be to get a custom built one with about 250-275A.
