Need some help wiring
Username: Ermano
Chicago, Illinois Usa
okay i need some advice on wiring my 6 12in kicker cvrs and a hifonics zrx3000.1D. how should i hook them up for best spl or sq
Username: John253a
Aust.
Post Number: 146
Are they 2ohm dvc or 4 ohm dvc
Username: John253a
Aust.
Post Number: 147
If 4ohm dvc
Wire in 3 loops from amp
2 subs in each loop
Wire each sub in series to 8 ohm
Then parrell the 2 together to give 4 ohm
Now you will have 3 circits of 4 ohm
Then parrell them all together
And amp will see 1.3 ohm
Each sub should see 420wrms
As amp is 1500@2 ad 3000@1
Username: John253a
Aust.
Post Number: 148
this may help also
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
