i recently bought a brahma 15" sub that pushes 1600 watts rms. i was wondering if a jbl bp1200.1 amp would b eable to power the amp so i have good sq and spl. if you wouldn't go with a jbl please recommend some other amps, regardless of the price. thanks guys.
thanks for your help. i found a prefab box at subzeromfg.com, if you have time to check it out. it says it is the best design for the brahma. if you have time, check it out and tell me what you think. thanks again
Robbie A JBL 1200.1 will work good with a Brahma. If I'm correct I think Glass and Jonathan recommends JBL 1200.1s for Brahmas and JBL 600.1 for Shivas. I have seen a LOT of people on this board with the same set up and they wasn't saying anything about problems with it. The box your talking about looks good I think it will be a good choice. Good Luck
