Helpp please........i need to make the decision soon
Username: Wardle
Brantford, Ontario Canada
Post Number: 14
hey i have 2 12" subs (sony xplod) i know they arnt any good but im planning on adding 2 10" earthquakes to the same box the sonys are in..would this be allrite.. this box has no air ducs it completely sealed. And i have a 1900 watt amp to run all four of these
would this be enough power to run all four of these?? thanks please tell me all u know thanks alot!!!!!
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4057
do not add more speakers to the same box airspace.
you'll end up damaging the speakers.
Username: Wardle
Post Number: 15
really...so its not a good idea to do this
Username: Wardle
Post Number: 16
how would it wreck the subs
if i put air ducs in the box would it be alrite
and why shouldnt i add more speakers the to same box airspace??
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 824
putting "air ducts" in the box would make it ported, tuning it to who knows what frewuency, and probably having a really strange resonant frequency... if you decide to get multiple subs, have them all be the same manufacturer / model and give them each their own airspace
if you add speakers to the same amount of space, say one has a higher excursion than another...it will compress the air inside harder and cause another speaker to decompress harder than maybe its supposed to
it will overexcurse, damage the spider or entire suspension or the surround and you'll end up with a broken subwoofer
ur better off rethinking ur plan
Username: Glasswolf
Post Number: 4059
actually the "air ducts" wouldn't raelly even be considered porting.
all it's doing is destroying the sealed airspace and turning the enclosure into an infinite baffle board, which destroys any damping for the speakers, which in turn will cause them to over-extend in short order and blow the cones out of the speakers.
adding different speakers in the same airspace causes the speakers to fight against each other, and the more powerful speakers will only succeed in blowing the cones out of the weaker ones.
Same reason you don't stick components or 6x9s in a box sharing airspace with subs.
also if you know *anything* about enclosure design and speakers in general you'll know that each speaker requires a specific amount of air space and that volume varies if the box is ported or sealed. If you go adding speakers, you need to increase the enclosure volume accordingly.
Username: Wardle
Post Number: 17
ok well i didnt do that
instead i picked up 2 12" kicker comp VR
are they any good
i payed 270 for both of them and a box
did i get ripped off or are these subs good?
Username: Jonathan_f
GA USA
Post Number: 794
You could have gotten them a LOT cheaper online. They are good subs for the money, though, good subs period for that matter.
Username: Wardle
Post Number: 19
what amp would i need to run these two kickers?
Username: Wardle
Post Number: 20
what amp would be good to get these subs running really good
i was planning on getting a 1400W amp
is this good or to much?
Username: Glasswolf
Post Number: 4065
nice subs.
the amp will depend on the impedance of the subs
Username: Glasswolf
Post Number: 4066
and no, a "1400 watt amp" isn't a good idea.
the subs are rated for 400 watts each at the most.
Username: Wardle
Post Number: 24
really
than how come he told me to get the 1400 watt amp
the 12" are only rated 400 watts each?
i thought 800w
GA USA
Post Number: 800
You're looking at peak figures. The RMS of the subs are 400 watts, RMS is the rating you want to look at. What kind of amp is it?
Username: Wardle
Post Number: 25
i think he said memphis or something
Username: Davids2004
Houston, TX USA
Post Number: 336
Are the kicker comps dvc 2 or 4 ohm.
