Better bargain woofer
stereo newb
i have three woofers that i am thinking of getting:
1. Memphis Power Reference
2. Phoenix Gold Ti
3. Funky Pup Quad
4. Quadrasub
which one would have the best spl/sq. i have a 5k budget and lots of space. and yes this is going in a vehicle.
Username: Grmncrsnbr
VA
Post Number: 217
and by three you meant four.....
I wish i had that kind of a budget good luck
Username: Jonathan_f
GA USA
Post Number: 760
If you have a 5k budget, why are you looking for bargain subs?
stereo newb
that way i can buy a whole bunch of them. i also need help finding a budget amplifier, can you help me?
GA USA
Post Number: 761
Out of those, I'd choose the Phoenix Gold TI's. For amps on a budget, I'd look at JBL, they're cheap, reliable, and put out more power then they're rated for.
Username: Lazarus
Keyport, New Jersey
I agree with Jonathan. I can get you a good deal on PGs.
