What's a good router?
Username: Skdooley
Roanoke, VA Usa
Post Number: 1565
Can anyone suggest a good router? I'm looking to start building my own enclosures and the first thing I'll need is a good, reliable router. Also, what kind of bits will I need? I plan to do flush mounts. I'll need a good template as well.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 24714
Routers?
Bosch
Porter Cable
Milwaukee
Dewalt (fair)
Get a plunge router, it will make you smile.
Bits?
Rounding over
Rabbiting
Straight slot
Get carbide bits as a minimum.
Set aside a good $250 for starters. Some drop $400+ easily.
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16989
^x2
in additon i prefer 1\2" r\bits though - they seem to run more sturdy than 1\4" bits ...
