Need some cheap 6.5 drivers with tons of mid bass, and 8" woofer
Username: Killerzracing71
Post Number: 2422
I had AA poly mids in my caprice, loved them till one blew.
Oh well, my daily a 2003 subaru Baja needs speakers all around, when It was new he mids sounded awesome. Now they are all crackling.
Any ideas?
Budget about $50-70 ea driver, rather not spend that if I have to.
Also the car has a little amplifier for a subwoofer, problem is the sub is a 0.8ohm woofer. So I need a 1ohm load for a 8" woofer.
I was looking at a Mach5 audio IXL 8 for the rear.
I loved my Mach5 audio Mj18ms alot.
Subwoofer, 150 or so
Username: Mmaudioconcepts
KY USA
Post Number: 754
Atomic Quantum 8"
Username: Wackzirth88
K-town, Il U.S.
Post Number: 450
Sundown sa8 or e8. Also dc's level 2 8s look to be pretty good
Username: Makinblak
Monroe/Monticello, La/Ar
Post Number: 424
has the x8 neo come out yet??
sundown?
Username: Nd4spd18
Philadelphia, PA
Post Number: 11749
If you want good quality speakers, need to up that budget by at least double.
Post Number: 2424
I'm realy not worreid about good quality, these speakers are blown. I just need something that works and hits like the factory speakers. Ill dump money into my caprice instead.
Those 8 posted look awesome.
Username: •cam•
BC Canada
Post Number: 2596
http://www.caraudioclassifieds.org/forum/showthread.php?t=67882
Maybe Mark has some left?
Username: Dsmith07
NC Http://com4....
Post Number: 969
http://www.soundsolutionsaudio.com/store/products/SoundSplinter-Orphan-8.html
Username: •cam•
BC Canada
Post Number: 2599
still looking??
saw this in the hot deals section of diyma
Peerless 6.5" HDS for $30
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=299-281&scqty=2
Username: Canaanwhiite
Monroe, Louisiana USA
Post Number: 8
if you want cheap look on ebay under pyle
