EA alts
Username: B3n07
Louisville, Ky USA
Post Number: 1189
i saw a 300 amp ea alt for 250 and was wanting to know if they where good alts
Username: Tejcurrent
Post Number: 2619
Is this for your daily driven vehicle, or competition? If for competition go for it.
If it's your daily vehicle I would make sure you're getting 100+ idling amps, and ask what diameter pulley it has, (particularly factory vs overdrive) because those things are important for daily use.
I owned "380" amp alts that bench tested 280 peak and 10 idle. Obviously I had to rev my truck at stop signs to keep my battery from dying.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11597
Short answer: No.
Several people just on this forum alone have had failures, problems, etc, do a search.
Also there was a thread a long time ago where somebody had one tested and found it to be way below claimed output.
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 16081
wow learned something new there
