Quick question
Username: Beerye
hello, just bought myself a k reg mr2, not got the car delivered yet, when i checked it out, never thought to check where i could stick my subs, i've got 2 12 inch alpine type r's, will these fit behind the seats? or am i gonna have to buy new smaller subs?? any help greatful
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5830
You never know you might be able to squeeze them in...but no one can really tell if they'll fit or not because we havent measured what kind of space your going to be working with...
Username: Delsole
Post Number: 1755
I have always loved those cars. Anyway try taking a few measurements and get back to use. If we know what kind of space you have to work with we can go from there.
Username: Nd4spd18
Philadelphia, PA
Post Number: 11561
A guy I knew in highschool had a first gen one of those... he thought 135hp and about as much torque as my trucks lugnuts take was cool... lol
Username: Glasswolf
Post Number: 14228
AW11 or SW20?
Username: Beerye
should be sw20, thought aw11 was the mk1's? seen some other forums with guys talkin bout subs in these mr2s, nd there sayin like 3 or 4 inch in depth subs would be a good fit, where as mines are like 6 or 7 inch in depth, seen some peope say u can stick them under the bonnet, but i reckon that would sound dreadful
Username: Livin_loud
MW2 Addict
Post Number: 3282
i really doubt you'll be able to fit them, but i could be wrong..
i'm with Gdub; turbo'd or blown? (or neither? )
