Purpose for bass knob?
Username: Dodge03quad
Post Number: 17
hey guys, i have a bass knob for my subs and not really sure how to use it or what the purpose is for it.
what level should i keep it at and is there a way to over do the power?
Username: Deadrabit
Marionville, MO
Post Number: 2470
turn it up all the way and set ur gain . that way you will not clip when you are playing with it. the purpose is to turn down ur bass. for comps i use my bass knob to roll into my burp.. its better on the equipment
Username: Skdooley
Roanoke, VA Usa
Post Number: 976
I didn't know subs came with bass knobs
Username: Mystre
Pemberville, Ohio USA
Post Number: 337
LOL SKD
Username: Nd4spd18
Philadelphia, PA
Post Number: 11219
Hold it there guys.... Theres two types of "bass knobs"
If it came with the amp its usually a bass boost control in which case it should NEVER be used. All bass boost gives you is clipping and distorted sound.
If you know for sure that it's a level control, then you can use it as kind of a remote volume control. If you don't have this, look into a PAC LC1. It connects in-line on the RCA cables at the HU and gives you a level control you can use with any amp.
