ok im gonna sell the 15xos and get a single fi q 18 dvc 1ohm and run that off that american bass sq880 in 1ohm for a lil i will buy a dif amp later on...box wise i will prob build a box for it...i did some measurments in the my trunk and it can work for a single 18 in prob a sealed box...or should i port? i already have a 120amp alt and new batt and have 4g wire.
if u want to run at 1 ohm you need a single dvc 2 ohm Q. I think thats a great idea, im also in the process of finishing my box for my 18" Q which will be ran off a sundown sae-1200d. I've heard great things about them in ported boxes with sq and they absolutely shine for sq in sealed, so ive heard. I am doing ported just for the fact i want to be loud, but still have some sq mine is going in the trunk of a 3 series bmw by the way so its def possible to make it work
ok ill order the dvc 2ohm but im gonna run it off the american bass in 1ohm for a lil so i can order the rims i want and do some window tint..but im thinking im gonna get a sundown 2000 later on
