False Floor
Username: Kdryden
Post Number: 110
Alright guys, i got my subs and amps, my installed is almost done and i will be posting as soon as its ready, my question for you guys is,
Do you guys think that i need to dynamat my wheel well if i create a false floor in mdf?
Im going for SQ so if i do need to dynamat my wheel well what would be the best deadener to use but it has to be easy to install.
Username: Domenico
BanginGMCArizona
Post Number: 798
Damplifier Pro FTW!
http://www.secondskinaudio.com/vibration-mat/damplifier-pro.php
&+ I have no idea what you are talking about.. maybe I am reading it wrong? Elaborate please.
Username: Kdryden
Post Number: 112
Basically im going to put a sheet of mdf on the trunk floor should i dynamat under it or is the mdf floor enough
Username: Domenico
BanginGMCArizona
Post Number: 803
I dont think anyone can fully answer this question. Put the system in and if it needs it.. it needs it, if you dont want to wait and see then do it before hand. Ya hear me knockin nikka?
Username: Snowball123
West Allis, WI
Post Number: 3432
Deaden underneath the false floor, the MDF won't help with the vibration alone.
