When selecting an amp for speakers, is it better to get an amp that puts out closer to the max power of your speakers, the RMS power of your speakers, or somewhere in the middle?
I PURCHASED A VIRTUAL REALITY SOUND LAB AMP. 4.1, 1000 WATT, 5 CHANNEL. IT WAS THE LAST ONE AND THE BOX WAS OPENED, ALL DIRECTIONS AND AMP INFO WAS MISSING. I'VE TRIED 2 TIMES, WALMART WAS UNABLE TO HELP ME OBTAIN AN OWNERS/USERS MANUAL. HOW CAN I ORDER THE PAPERWORK INFO FOR THIS AMP?
Da_Bears
Only thing I can think of is to write the following address to get warranty information and hopefully it will give you a lead to where you can get a manual. Attn: Warranty Department Walmart.com 7000 Marina Boulevard Brisbane, CA 94005
Make sure to include the following information: Name of the manufacturer of the item Item's model number, and/or a description of the specific item for which you are requesting a copy of the warranty.
Other option is to check Walmart's in nearby cities and see if they have one. Maybe you can convince them to open the box so you can make copies of the manual.
