Sumbody plzzzz help me!!!
Username: Trevinoau
LA
Posted on Monday, January 04, 2010 - 02:53 pm:
I just got 2 10" compvt kicker subs for my single cab truck.
I need sum suggestions for an amp to push it and whether i shud build or buy a box.
Username: Gcs8
Atlanta, Ga
Post Number: 166
whats the rms of the subs? and eather build a custom box or buy a custom one for those subs.
Username: Trevinoau
LA
The rms for em is 400.
And they r 4ohm if that makes a difference.
Should it be a dual box or two separate boxes?
Username: Gcs8
Atlanta, Ga
Post Number: 168
is that rms combined or for each? pref a dual box but can be separate if it has to be but thats rare for 10"s
Username: Dustin3
D&L Audio Tech.Dustin
Post Number: 5234
A dual box would be best. I see that you live in LA, i'm up in Portland and can build you an enclosure for a good price...
Username: Gcs8
Atlanta, Ga
Post Number: 170
SAZ-1000D or SAZ-1500D for the amp can find one used for a good price.
Username: Trevinoau
LA
its 400 rms for each sub.
and bassman3 about what price range shud i expect?? I'm pretty interested as long as i'd b able to see other boxes u've built
also where shud i look for the used saz-1500D? and how wud i know if it worked and all that, since it wud b used and all.
Username: Gcs8
Atlanta, Ga
Post Number: 175
http://www.caraudioclassifieds.org/forum/forumdisplay.php?f=71
Username: Gcs8
Atlanta, Ga
Post Number: 176
http://www.sundownaudio.com/index.php/products/amplifiers/saz-2000d.html
http://www.caraudioclassifieds.org/forum/showthread.php?t=26595
will put you right where you should need to be.
Username: Skdooley
Roanoke, VA Usa
Post Number: 173
He built me a box Austin and had it shipped all the way to VA. It arrived perfectly and was built great. I recommend Bassman.
