New member Username: MattwedemPost Number: 4 Registered: Nov-09 | I just got 2 12" aw122n. I figured there would be more low end than my 10"s. There is absolutely no low end on them. I gets highs very nicely but my 10" W0 got lows better. I think i am doing something wrong. there are also 4 positive and negative terminals on it and I am confused, Please help. Also its off a 1000watt Kenwood 8101D. |
Gold Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 1072 Registered: Aug-08 | i take it these subs are D4 ohm so wire it up like this http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4 and it could be the box |
Gold Member Username: Kingandsons07TEAM NEBRASKA Lincoln,NE Post Number: 1073 Registered: Aug-08 | http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4 |
Platinum Member Username: Rovin1 15 = 152.5 DBs ...Trinidad & T... Post Number: 15707 Registered: Jul-05 | most likely : enclosure ... |
New member Username: MattwedemPost Number: 5 Registered: Nov-09 | I have found out my ported box is tuned too high is there any way I can tune it lower without building a new one? |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10790 Registered: Jul-06 | Audioburn.... get some decent subs before putting anymore time/money into it |
New member Username: MattwedemPost Number: 6 Registered: Nov-09 | there is nothing wrong with my subs they are fine for what i need so if your just gonna give me crap take it elsewhere cuz I could care less what you think. |
Silver Member Username: Purplehase_bongBC Canada Post Number: 378 Registered: Apr-04 | Matt, M.S. is a goof, dont mind him. my suggestion is to build a custom box. for what you want, a "Transmission Line" enclosure would be best, would definetly bring out the lows. heres an example http://i29.photobucket.com/albums/c265/xnbastar1669/DSC00012.jpg some guys here refer to it as a "snail shell" box. |
Gold Member Username: Wolf_houndPhoenix, AZ Post Number: 1107 Registered: Sep-05 | Do you need to use transmission fluid on that enclosure? |
Gold Member Username: Livin_loudCOD4 Addict Post Number: 3012 Registered: Jan-06 | thats probably a tad bit advanced for what he needs. a simple ported enclosure will do fine. if you ask nicely somebody on here probably wouldn't mind drawing you something up. granted you have basic wood working skill and access to tools you could build yourself a box, or pay somebody to do so. whatever you do, don't buy a prefab from wal-mart, etc. |
