Hows this set up sound?
Username: Hockeytoker
Post Number: 62
2 12" Audioque HDC3 running on a audioque 2200d amp at 1 ohms.( should i buy the dual 2ohms and bridge them to run at 1 ohms? or if i buy 2 of them at 1ohms can i run them at 1ohms?
with this alternator http://powerbastards.com/proddetail.asp?prod=Fitzall-220
this battery http://www.millionbuyplus.com/view_product.php?itemno=KINKHC1400
and a big 3 wire upgrade.
is all of this electrical upgrade needed to run this set up?? my car is a 98 camry all stock. the alt puts out 90 amps
Username: Wolf_hound
Phoenix, AZ
Post Number: 973
sounds great son
keep up the good work fosho
Username: Dangeranger
Ohio United States
Post Number: 125
Buy two Dual 4's. If i were you I'd upgrade alternators 2200rms on your alt will hinder performnace.
Post Number: 63
they dont come in dual 4's they only come in 1 and 2...
so should i just upgrade the alt? and not the big 3 and battery?
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7190
get dual 1s.
Post Number: 64
can u run 2 subs dual 1ohms at 1ohms on one amp/?
Username: Insearchofbass
York, Pennsylvania
Post Number: 12032
Yes
Post Number: 65
so i should just get 2 dual 1ohms and wire it at one ohms instead of getting 2 dual 2 ohms and bridging them to have it a 1ohms?
York, Pennsylvania
Post Number: 12035
2 dual 1 ohms wires to 1 ohm or 4 ohms
2 dual 2 ohms wires to .5 ohms or 2 ohms
So yes get the dual 1 ohms.
Username: Armykyle1
Ms Us
Post Number: 709
there is no bridging!!!!!!!!!!!!!!!!!!
Get D4s, It wires down to 1ohm
Post Number: 66
THEY DONT COME IN DUAL 4'S!!!!!!!!!!!!!
Username: Drant19
DUB-C, TX
Post Number: 1973
dual 1 ohm is what you want.
Username: Cal1089
Post Number: 52
here very helpful take a look
http://mobile.jlaudio.com/support_pages.php?page_id=161
Post Number: 74
thanks for the site man!
