Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 7001 Registered: Nov-05 | Ok.. I've got two 3250.1s.. they appear slightly different. Was just curious about the older one I have.. It has gold plated inputs/outputs and the RCA input/bridge is different The older one seems to be more powerful than the newest. Was there a known issue with the old ones with the RCA input/bridge? Today it started having no output.. sometimes it would come back and other times not. But nothing seems loose. Could just be my outputs from the headunit going out or some bad RCAs. So I was just curious about the difference in the two amps and if the new ones had changes to the design if there were known issues with an older line. new old |
Silver Member Username: TeamrevolutionATLANTA, GA USA Post Number: 678 Registered: May-07 | sounds like a there could be a cracked solder. Try making the amp i just sent you the master amplifier. If will still play if the other one isnt doing anything so make sure you listen to what one sounds like so you know if its actually working |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2011 Registered: Jun-07 | steve iv got a problem too. what ur ur number? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 11847 Registered: Jun-04 | 770-975-9100 blk did you see I posted a 4th order bandpass program on the bandpass thread? Theres also an 6th order program ill post that one too. |
Gold Member Username: DeadrabitMarionville, MO Post Number: 2013 Registered: Jun-07 | no sean i didn't see that! can u please post it again? thanks |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 11853 Registered: Jun-04 | https://www.ecoustics.com/electronics/forum/car-audio/579869.html |
