~!~ a question that needs an answer ~!~
Username: Basshead911
Post Number: 15
does anyone thin i can fit a 1 18'' Fi BTL in a 96 pontiac grand am
im willing so sacrafice every inch of my trunk lol
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 3608
I'm sure it could be done. Are you stuck on the BTL?
Username: Kingandsons07
TEAM NEBRASKA Lincoln,NE
Post Number: 665
or 18"?
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2720
Personally I wouldn't try it. I think it would be more trouble than what it's worth. I'm going to say probably not (unless you can go from the inside or build the box in the trunk).
Username: Southernrebel
Post Number: 7546
Depending on the actual size of the trunk, which in your case is pretty small, you can put too big a box in there. If it is too big, very little sound will get into the cabin and the trunk will just rattle like crazy.
Username: Basebalz13
Moneta, Va Usa
Post Number: 1677
youll get alot louder with 2 12's
installed a single BTL/Mayhem 18 in a caviler similar trunk sizes and it was not loud, i warned the guy but he didnt listen
Username: Loc_out
SoCal
Post Number: 2982
Ray Ray use to have an 18 on a bonneville. Which I believe has a bigger trunk. Last thing I heard he wasn't too happy with the setup.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3676
2 12s or 1 15.
