Cheapest amp with 200 amp fuse rating
Username: Mendonmafia
Post Number: 1486
as the title states whats the cheapest amp out there with 200 amps of fusing or more.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8755
Why do you care about fuse rating it tells you nothing about the amps actual output
Post Number: 1488
well then fine let me rephrase my question. whats is the cheapest amp that will do a GENUINE 2400rms or more @ 1 ohm @ 12 volts?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8773
American Bass VFL-200.1
Sundown SAZ-3000d
RD 3250.1
or if you can settle for 2200w
Audioque 2200d
RF t20001bd
all are great amps
Username: Nd4spd18
Philadelphia, PA
Post Number: 8774
As far as price goes, good quality amps of that size are anything but cheap.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5766
best bet is going with the AQ 2200d for the price and what your looking for
you gotta pay to play, remember that
Post Number: 1490
i understand its expensive to get quality at this power level but i didnt say it had to be low cost did i? all i want to know is what is the cheapest price amp that will do what i need.
Post Number: 1491
why is that rockford amp so underrated. ive heard people getting much more than 2k out of them even @ 12 volts.
im looking for somthing a little more than the AQ amp pretty much.
Username: Drant19
DUB-C, TX
Post Number: 1291
pretty much all RF amps are way underrated. a friend of mine had the T5001bd and the birthsheet said like 900something. its just RF for ya..
Username: Th3pwn3r
I compensate...
Post Number: 8837
"all i want to know is what is the cheapest price amp that will do what i need."
Why didn't you just ask that in the first place you dumb @ss!
Post Number: 1492
i did. but i asked the wrong question supposedly, even tho every amp listed has a 200 amp or higher fuse rating.
Username: Th3pwn3r
I compensate...
Post Number: 8839
I was just messing with you by the way. I think you're a retard, not a dumb @ss.
Username: Faroutdesign
St.ptersburg, Florida Usa
Post Number: 29
go old school you cant loose. check some pawn shops till some one with like an old school us amp or orion pawns it for 50 bucks and grab it for double. it may need a lil repair but whats a couple hundred bucks to something like a 600 dollar amp
Username: Van_man
Boston South, MA
Post Number: 4410
audiopipe 3000d
"I was just messing with you by the way. I think you're a retard, not a dumb @ss."
Im still loling...
Username: Southernrebel
Monroe, Louisiana 3 DD3515s, 2...
Post Number: 6897
I have an IA 20.1 up for grabs.
That would be more than enough for ya.
Post Number: 1493
this is true. how much tho.
i am a little retarded so i guess ill let that slide, but i aint no dumbazz.
Username: Deadrabit
Marionville, MO
Post Number: 980
aq is good for the money. u might be able to get one of those RDs cheap maybe. if u do let me know how much cause i kinda want something bigger
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14292
IMHO the best econo amps r hifonics brutus series ...
Post Number: 1494
not enough power tho for the Brutus models.
