I could use some advice
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 618
Heres the deal: I want to upgrade my front stage, but I am limited by several factors. I only have space for 4x6 coaxial or 4"components. I don't want to fiberglass, because I have no experience with it and I don't wanna practice on my car. I don't want to do anything permanent. Also i do not want to spend over $150 because I am on a budget. I don't need anything incredibly loud, I just want it to sound real nice.
So do i go 4x6 coaxials or 4"comps? Which ones should I get?
I will be amping them if necessary.
What should I do?
Username: Poundhardheh
Palmerston, Ontario Canada
Post Number: 12
comps, and amp em!
Username: Th3pwn3r
I compensate...
Post Number: 8827
Have you considered Q-Logic kick panels?
Username: Ducka
Post Number: 620
Thats what i was thinking. I know I wont get much midbass, but my subs have a pretty good range and I think the comps will get just low enough.
The question is what comps?
I was lookin at CDTs, diamond audio, and MB quart on woofersect.com
Username: Ducka
Post Number: 621
I have considered the Kick panels, but I have an alero and there will be next to no leg room. :-(
Post Number: 13
I really can't tell you what kind, just look for the bigger frequency range and watt handling. Or do kick panels, they are nice for sound and look nice. But depends your car.
Username: Ducka
Post Number: 623
Anyone else got any suggestions?
Username: Insearchofbass
Post Number: 10683
You could put components in your front doors factory locations if you have them. And do slight mods for positioning if needed.
Username: Ducka
Post Number: 624
Thats what i was thinking, but Im gunna have to go with 4" comps. What would be a decent pair for around 150?
Post Number: 10688
Talk to alteraudio and see what he says is best for your situation. He also can get discounts.
Username: Ducka
Post Number: 626
i dont know who that is
Username: Nd4spd18
Philadelphia, PA
Post Number: 8729
Mike from exige audio can get awesome prices on the CDTs
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2396
The point is that you can not fit anything bigger in the Alero's doors. The way the panel is shaped and also the depth between panel and the window is a huge factor. It really sucks lol.
Kevin, send me your map pockets and I will glass them lol.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8734
That sucks but try having a first gen S10 or Blazer..... you get NO speakers in the doors and no depth to flush mount anything
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14285
i cant see 4" doing much for some1 who is really into music - i say cut the damn doors & fit some real speakers there like 6.5" comps ....
Username: Basebalz13
Moneta, Va Usa
Post Number: 743
hmm you want some comps dont ya let me see what i can do
Post Number: 10689
"Mike from exige audio can get awesome prices on the CDTs"
Thats who I meant.
