Okay subs for my friend for cheap system
Username: Santa_fe
02 Hyundia Santa Fe, 120.3 db not...
Post Number: 501
okay he likes rock mostyly and some rap so the subs i found are http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4904
now for the amp i was thinking
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4210 wired in parallel any ideas on thoes subs are they decent?
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 609
RE is a good brand, Idk how they're low end stuff is though.
Another option to consider would be like a 15" type-r
Username: Ducka
Post Number: 610
I would definitely look into a 1 subwoofer setup for him. Rather than buy 2 cheap woofers get 1 decent one.
Other brands to look into:
JL
Kicker
Image Dynamics
AudioQue
Infinity
MB Quart
Diamond audio
Cerwin Vega
boston Acoustics
I already said Alpine
Username: Insearchofbass
Post Number: 10665
I dont think the re 10 will be loud enough for your friend. A alpine type r would probably be a good choice for low and high end bass.
Post Number: 10666
alpine type r 10 dual 4 87.04 plus shipping
http://www.etronics.com/p-1103-alpine-swr-1042d-10-type-r-series-subwoofer-4ohm- 4ohm.aspx?dp=225232B2E6825253D3836323A3570373637323132303&sbvname=30&bname=Price Grabber
or a alpine type r 12 dual 4 $99.04 plus shipping
http://www.etronics.com/p-1120-alpine-swr-1242d-12-type-r-series-subwoofer-4-ohm-4-ohm.aspx
alpine m 500 149.00 shipped with a 3 year warranty
http://www.dealercostcaraudio.com/MRP-M500.aspx
or you can go with a alpine m 650 for 600 watts at 199.99 shipped with a 1 year sonic electronics warranty.
http://www.sonicelectronix.com/item_6471_Alpine+MRP-M650.html
Username: Nd4spd18
Philadelphia, PA
Post Number: 8695
NOOO on that amp. Hifonics txi amps suck and are way overrated
Post Number: 10673
If you dont like that place for the alpine sub heres the alpine 10 at online car stereo for $115 shipped with a 1 year warranty.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14952
and the alpine type r 12 for 132 shipped.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14954
Username: Santa_fe
Post Number: 502
hmm this is what i love about E thankx for all the other options that i dident think about....mmm space is BIG issue and he seems to really want to tens....may go with the apline amp you suggested and MS thanx for the NNOOOOO on the amp you confermed my suspicions
Username: Ducka
Post Number: 613
trust me he will be alot happier buying 1 good sub rather than 2 sub par subs. That alpine amp with a 10" or 12" type-r would be a pretty nice setup.
Post Number: 10674
I thought you were only looking for one sub so I planned around that so if your planning on running two 10's youll need dual 2 ohm voice coils.
Username: Santa_fe
02 Hyundia Santa Fe, FI SSD. Hifo...
Post Number: 504
are you talking for that amp that you reccommended?
Post Number: 10675
You could also go with a single alpine type r 15 dual 4 ohm for 205 shipped and have more cone area than 2 10's. It just depends how much room you you have.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14956
Alpine SWR-1542D
# Sealed box volume: 1.3-2.5
# Ported box volume: 1.5-3.0
Alpine SWR-1042D
# Sealed box volume: 0.5-0.8
# Ported box volume: 0.6-1.25
Post Number: 10676
"are you talking for that amp that you reccommended?"
Yes
Username: Santa_fe
Post Number: 507
ahh yeah space is quite tight....its an RSX and he moves alot of stuff in the back for his work....so but thanx a bunch for all the help
Username: Shortysetnies
Andrew Capps, NC US
Post Number: 2904
I've got a 10" BL and a RD 1000.1 for 400 plus shipping.
Let me know if you like that. Id also be willing to sell seperatly. If you're interested, email me at shortysetnies@aol.com
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 6169
f*ck a ten. i would say go with a 12 at least.
Post Number: 10678
If you dont mind a refurburished amp heres a kicker 750.1 for 209.59 shipped they under rate them. Some of those amps produce near 900 watts on birth sheet.
http://www.techronics.com/index.cfm?fuseaction=product.display&product_id=4267&a ff=45847
Username: Nd4spd18
Philadelphia, PA
Post Number: 8714
" *ck a ten. i would say go with a 12 at least. "
Typical ignorant and stupid reece comment.
I run 2 10" Fi Qs and it sounds great...... I like to play it for dumb people who think "10" subs don't have good low end" and watch their jaws drop. I also remember a DD system with 2 9510s that did over 150 db.
Username: Snowball123
West Allis, WI
Post Number: 1486
he means just one 10 compared to one 12 though.
