New member Username: Caddyman18Post Number: 3 Registered: Jun-04 | can anyone help me wire a 1600 Volf amp and 2 12" volf subs? |
Bronze Member Username: JayjPost Number: 26 Registered: May-04 | You could have got a better set up for LESS money. give me the specs of the subs and amp and I will post a wiring diagram for you. |
New member Username: Caddyman18Post Number: 6 Registered: Jun-04 | Amp=Maximum power output @ 2ohm 800W x 2 = 1600W Power output: 3200Wx2CH@2ohm(640W) 220Wx2CH@4ohm(440W) Bridged Power 640Wx1CH@4ohm 2ohm stable stereo Tri-mode capable Fan cooling system Variable bass boost:0-18dB Variable bass frequency:30Hz-100Hz Channel seperation:>60dB Signal to noise ratio:97dB THD 0.03% Frequency response:20Hz-20KHz HPF:50Hz-1KHz LPF:30Hz-250Hz Adjustable sensitivity range:0.1V-1V Input impedance:Low level(10K ohms), High level(100 ohms) SUBS=1000 Watts Max Power 500 Watts RMS Power Dual Voice Coils Aluminum Cone Rubber Surround Coated Tinsel leads Double Magnet Structure Oversized Vented 4- Layer Voice Coil Bumped T-Yoke Double Damper Gold Plated Spring Loaded Terminals Aluminum Die-Cast Basket Recommended Sealed Enclosure 1.25 Cubic Feet the subs are 4 ohm DVC thanks for your help |
