Problem with system
Username: Kissdaredevil
Post Number: 33
My system was working fine (subs,amp) I swapped out my CD player with one I had in another car that was running a system just fine. Now my subs hum when the volume is down. I checked the ground on the amp and it's fine. I checked the RCA's and there fine. Could the ground on the CD player cause them to hum. None of the other speakers hum. If not, what else could make them hum
Username: Bonhamd
Post Number: 1148
what kind of HU do you have?
is it a Pioneer?
Username: Brewsky
Prince george, British colu... Canada
Post Number: 110
i had the same problem kinnnnda check your fuses and remote,,,, make sure your rcas arnt fuccckkkked at the ends thats what happened with mine my box moved a bit and bend one of the ends of them on my wheel wel
Post Number: 34
the one I just put in is a pioneer. I didn't have problems with it before however
Username: Bonhamd
Post Number: 1149
try grounding your RCAs
Username: Hittin1
Lake Charles, La. United States
Post Number: 1255
X2^^^ ground RCA's
Someone post a pic... I've seen it on here b4..
Post Number: 35
How do I ground the RCA's
do I ground them at the back of the head unit or at the amp or doesn't it matter
Username: Nd4spd18
Northwest PA
Post Number: 8436
Yep sounds like the POS pioneer RCA problem
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 372
i had that problem one time and the RCAs werent plugged in all the way but it was a JVC HU but try grounding the RCAs
Username: Tanmanfosho
Fi SSD15 Wangers
Post Number: 1143
other than being annoying is the subs humming bad?
Post Number: 36
you can only hear the humming when the volume is all the way down.
