Box for audioque hd315
Username: Bernymac
Cambodia
Post Number: 4206
Hey guys, I'm trying to design a box for my friend for his single audioque hd315. He has a max dimensions of 31 wide, 16 height, 20 depth. I used the RE enclosure calculator and came up with this. What do you guys think? Overall I think he'll have enough with these dimensions.
Username: Joebruce
TC Sounds/DLS
Post Number: 2358
I could care less! You're too good for chat anymore so I dont care :-(
Username: Bernymac
Cambodia
Post Number: 4207
Ok, I was able to find my old thread in which sean recommended that I use 3 4" aero ports. Which would cost $50 shipped from PE.
Heres the thread
https://www.ecoustics.com/electronics/forum/car-audio/504914.html
So I redid some calculations
31 x 16 x 20 external dimensions
29.5 x 14.5 x 18.5 internal dimensions
4.58 internal cuft volume
4.58 - .30 - .25 = approx 4cuft
Now I don't know how long I would need ot make the aero ports or how shorter to make them if I increased the size of the box to 4.58cuft before sub and port disp. But I think that if I'm going to use the aero ports, that I'll have somewhere in the range of 4cuft after sub and port disp. So if anyone can chime in that would be great.
Username: Bernymac
Cambodia
Post Number: 4208
"I could care less! You're too good for chat anymore so I dont care"
Sorry Twiz, I was in Pomona picking up my friends Chrysler 300 from getting his audio installed and afterwards I let him borrow one of my subwoofer box's so he can have some bass since we didn't get him a box built yet. I can't believe we spent upwards of 6 hours or so. I'll be online tomorrow forsure after 10pm when I get to work forsure.
Username: Deadrabit
Post Number: 715
dont for get the displacment of the sub and ports!
if there is for comps aero would be good
but for hitting the lows i would use slot port but who konws
Username: Deadrabit
Post Number: 717
if this is for comps aero would be good
Username: Hittin1
Lake Charles, La. United States
Post Number: 1120
" would need ot make the aero ports or how shorter to make them if I increased the size of the box to 4.58cuft before sub and port disp. But I think that if I'm going to use the aero ports, that I'll have somewhere in the range of 4cuft after sub and port disp"
hey dBLK.... I think he got that covered..
Username: Insearchofbass
Post Number: 10309
If you leave the port length a 13.75 each youll be at about a 39 hz port tune. But if you want it tuned to 40 hz go with a port 13 inches long.
Username: Bernymac
Cambodia
Post Number: 4210
Is that with the new internal measurements?
29.5 x 14.5 x 18.5
If so, thanks. I want to get the box built soon bc its in like a 3.5cuft box or so tuned really low and it sounds horrible.
Post Number: 10322
yes thats with the new measurements. How low is it tuned in the current box? And how exactly does it sound bad? Did you give the port enough clearance? I assume your 18.5 is the new box depth.
Username: Bernymac
Cambodia
Post Number: 4211
yeah 18.5 is the new box depth.
the box it is currently in isn't made for the sub at all. He just wants to use something in the meantime for a little bump, told him not to turn it up to loud until we get his new box. and yeah, it sounds really really bad. If it was me, I would take it out until I get a new box built haha.
