New member Username: LetstalksoundPost Number: 3 Registered: Dec-05 | Hey I need help designing a box. it's for 2 Treo ssi 12" subs (SSi12.22) all the specs needed are here (i believe) http://www.treoonline.com/infosheets/ssi_subwoofers.pdf I would like the box vented much like Seth Walker's post on this page with each sub to have it's own port https://www.ecoustics.com/electronics/forum/car-audio/222350.html I'm not sure what frequency would be best to tune it to, any suggestions would be great... listen to a mix of rap and rock, but use the sub more for rap looking for SQL (35 Hz??) space in truck, max box size is: 15.5 x 36 x 30(HxWxD)inches. this is the biggest box size possible, if it can be tunned correctly with a smaller depth or something that would be great. wanna use 3/4 inch mdf and do I need to double up the front so it's stronger, (2 (3/4) pieces stuck together) if you need any more info let me know thanks in advance |
Silver Member Username: Surferdude9371Im BTL Bumpin Post Number: 930 Registered: Mar-07 | best thing to do is get in contact with phil at woodlawn cabinetry or BJ at fisher cutstoms they both design boxes and build them doing a great job |
