hi i dnt no much about car audio so can anyone tell me if cuspid is good? there really cheap and they look good but i dnt no how the quality of them are so can anyone help me out? and also which brands are good for amps at a cheap or decent price?
cuspid amps like the Cuspid AM-4310 which is supposed to be 1600 watts arent very good. lots of people talk crap about them but they dont want to take the risk of trying them. i got an amp from them for about 45+ shipping. it was srap when i got it but i noticed that the fuse was only a 15 so i put in a 20 and then a 25. after that my subs kicked tons of times as hard. once you get it change the fuse. it will make all the difference in the world. dont put in a 30 though cause that will probably be too much.
Glass Can You Help
Is that true, can you take a amp a nd change the fuse to a higher amp and make it stronger like richard said.
richard you are crazy. I have a amp with 2 20amp fuses and I replaced them with 2 30amp ones and it didn't do ANY different. All that will do is let to much power come to the amp and burn it up.
No, you can't. That's crap. All a fuse does is blows if the current gets too high, and since that amp isn't supposed to pull more than 20, a 30 isn't gonna do a bit of good except burn the amp up.
Josh Lane
yeah see, I just traded 2 10" Infinity's for 2 12" Pioneer's 400w and a Cuspid Extreme 1600w 4 channel AM-4310 but I was just lookin to sell them. I found the price for the Pioneers and I found about $80-$100 for each sub but I cant find a price for that amp. Dont know what to ask cuz Im not real smart on car audio. Curious if anyone knows, its brand new though.
