Bronze Member Username: ZesterGardena , California Post Number: 36 Registered: Jan-08 | i like to connect an amp to my hu, from the amp i already have the ground and battery wire connected to the car, but i dont know what kind of wire do i need for the remote from amp to the hu? can i use any wire for that? does it have to be a blue and white color wire? |
Silver Member Username: WaresgaragestereoFort Valley, GA United States Post Number: 114 Registered: Jan-08 | wire is wire. no matter the color. its easier to identify the remote if its blue. get some 14 or 12 GA wire and run it from the HU to the amp. ther you have it! |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6065 Registered: Jul-06 | What is it with you people thinking you need huge wire for the remote........ https://www.ecoustics.com/electronics/forum/car-audio/445811.html And don't make multiple threads |
Bronze Member Username: EwokFairbanks, Alaska U.S.A. Post Number: 27 Registered: Jan-08 | i made 2 threads about the remote wire things, because i just wanted to make sure some1 would see it right away and i would get multipe advices. buy thanks again |
Bronze Member Username: EwokFairbanks, Alaska U.S.A. Post Number: 28 Registered: Jan-08 | sorry man, im not as good as you guys, im just a beginner in car audio tuning |
Bronze Member Username: TypejlHopkinton, Iowa United states Post Number: 19 Registered: Jan-08 | you dont need that big of a dam wire for your remote 12 or 14 gauge.. thats retarded |
