I need a box!
Andre G.
hi everyone i own 3 12s w6 ae's and im putting them in the back of my 2000 extended cab f150 and im planning to take out the back seat does any one out there know what kind of box i should use? any websites or where i could check them out would be really helpful THANX ALOT.
Username: Glasswolf
Post Number: 467
www.jlaudio.com
Andre G.
Hey thanks for the website but they only have enclouseres for 2003 models and the w6 ae's are discontinued any where else i could find help THANX and is bigger better?
Username: Tikolx333
Post Number: 75
dude find your local discount car audio or streo shop, not cartoys but the ragedy shop that sells brand that you have never herd of then go in there find the box you need make sure its the right air space and made of at least 3/4 mdf then buy it. if it cost more then 120 your paying too much check out ebay too.
Username: Redskin
Post Number: 21
If the w6ae's are discontinued why are they still on JL's web site. Are you sure you're looking hard enough? If your sure you are then why didn't you find this..............
www.jlaudio.com/subwoofers/pdfs/10_12W6AE_MAN.pdf
