Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1686 Registered: Mar-06 | I'm clueless about this stuff but I need 8 mosfets and when I look on them I see: IRF3205 1(funny lookin symbol)509K 8F 8C What do I need to look for when buying new ones? Will anyone that says "IRF3205" work or what? Thanks |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7425 Registered: Feb-06 | u got to replace them all not only the ones that looks damaged... |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1687 Registered: Mar-06 | So you are saying that, even though the ones with the arrow are the only burnt ones, all the ones circled have to be replaced?![]() |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7427 Registered: Feb-06 | that is the output supply so u gotta replace them all... is a class d circuitry so the parts MUST MATCH class d have very lil tolerance... is better for you to change the output section too... the other rows of mosfets they might look new or fine but they might be internally damaged |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7428 Registered: Feb-06 | it looks like a kicker amp is it? |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1688 Registered: Mar-06 | yeah zx750.1 |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7430 Registered: Feb-06 | why dont u send it to kicker??? they repaired my kicker kx2500.1 for 112 including free shipping because i received blown wiht no warranty.. u should do that... or buy the EXACT parts if u replace one mosfet u must replace them all that are the same part number |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1689 Registered: Mar-06 | "all that are the same part number" OK thats better. Thats what I thought. I was going to do that and you said all so I was worried. I pulled all of the same part number... If I do it myself it will cost about 25 bucks all said and done and I'm a cheap azz. haha |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7431 Registered: Feb-06 | well how much u wanna beat just chaging the mosfets yourself is gonna end up costing double or triple than 25 bucks?? is not just that bro there are sometimes parts that look brand new but went damaged because of the mosfets went bad.... u can change them and then try it back and its gonna blow again if you didnt check other parts.... u should sent that amp to a profesional |
Gold Member Username: 420alldaylongPost Number: 3175 Registered: Sep-06 | I(think)you also get a 90day warranty if Kicker repairs it. |
Gold Member Username: RideredderCornell, IL USA Post Number: 1303 Registered: Sep-05 | "there are sometimes parts that look brand new but went damaged because of the mosfets went bad...." That is true. The whole board could have gone bad because of that. |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1690 Registered: Mar-06 | ![]() Well I already have it apart. I will try it and if it screws up I will send it off or get a new one. I already have the mosfets out... |
Gold Member Username: Sinful_systems7015 INCH WANG... Post Number: 1184 Registered: Nov-06 | If you repair yourself, be careful because some are power mosfets and some are amplifier mosfets. Just be careful when you replace to make sure you use the cvorrect kind of mosfet... JMO |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1694 Registered: Mar-06 | see thats what I need to know. I am CLUELESS about this stuff. Completly clueless Will these work? http://www.mouser.com/Search/ProductDetail.aspx?qs=mLGruWOCTdGsMYrGdtnHEQ%3d%3d |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 7434 Registered: Feb-06 | your gonna fu-cked it up more man.. plus the driver board could be damaged its alil board that controls the switching of the mosfets |
