Silver Member Username: Dub_cPost Number: 330 Registered: Mar-06 | Sorry for being long I was going to turn my car on to warm it up and before I got to do that I dropped my clarion faceplate. I picked it up and the all the buttons work except the folder up and folder down button. I took the faceplate off shook it and there is something loose in there. IS THERE a place I can buy a new faceplate? Just the faceplate. |
Silver Member Username: B3n07Louisville, Ky USA Post Number: 665 Registered: Jul-07 | check on ebay i know they have a ton of face plates |
Silver Member Username: Dub_cPost Number: 331 Registered: Mar-06 | No ebay for me. |
Gold Member Username: Tatonka-[Team Audib... Post Number: 1332 Registered: Mar-07 | No faceplate for you. |
Silver Member Username: B3n07Louisville, Ky USA Post Number: 668 Registered: Jul-07 | then it looks like googles calling your name or your warranty might needed to be used |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 1119 Registered: Mar-07 | Last month my faceplate stopped working too. All the buttons did not work except for the volume. I had to send it in to a service center and they fixed it for free under warranty. It ended up being some small IC chip in the faceplate. I think they just gave me a whole new faceplate All the old scratches were gone. |
Silver Member Username: B3n07Louisville, Ky USA Post Number: 675 Registered: Jul-07 | lol im sending my pioneer in for servicing for the same problem except i have a wing noise and also the cd player quits playing when ever it wants |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 1122 Registered: Mar-07 | yea mine acts wierd still. Im buying a new one soon. |
Silver Member Username: Imi4tth3wSan Antonio, Texas USA Post Number: 139 Registered: Feb-07 | i've been having a problem but i just can't figure out whats doing it. i have an alpine 9856 with the ipod apdapter cord, and whenever i leave my ipod 80g, not the newest one, but newer it somehow kills the battery whenever i take it out. well it doesn't kill it but it just won't turn back on unless its plugged in, and when its plugged in it says full battery. so whenever i want to listen to my ipod in my car when its connected i have to wait for it to boot up. i've had 2 ipods and 2 ipod cords and they both do the same thing so i'm thinking it may be the headunit. i'll try a couple of friends ipods and see if maybe i'm just really unlucky with ipods. |
Silver Member Username: Dub_cPost Number: 332 Registered: Mar-06 | So is there a site where you can buy face plates? My Clarion is like 2 months old, I dont wanna get a new one. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 5427 Registered: Jul-06 | Yep its called ebay ![]() |
Silver Member Username: Tiki89Post Number: 220 Registered: Oct-06 | ebay is your best bet but i found this with a simple 5 sec google search ..... http://www.facereplace.com/ |
Silver Member Username: Tiki89Post Number: 221 Registered: Oct-06 | If i were you i would take it apart and see what came loose and if its not broken just put it back were it was at. |
