Bronze Member Username: KhaePost Number: 75 Registered: May-07 | does any one no the spec for a strapped kx1200.1?? with a good chargin sytem |
Gold Member Username: camPost Number: 1203 Registered: Nov-06 | With the charging system to support them, I'd just double the RMS. Although, you can probably expect a good 2.6 to 3 kW. How do you strap A kx1200.1? I was under the impression that you needed two of them for strapping... ![]() Hopefully you meant two of them.} |
Silver Member Username: Dubmc23Rapid City, SD USA Post Number: 165 Registered: Sep-07 | lol cam^^ |
Bronze Member Username: KhaePost Number: 76 Registered: May-07 | yeah lol two of them lol |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5052 Registered: Dec-05 | go to lanzar.com and download any manual of a mono amp, they always bring How to Strap info with diagrams and everything, pretty cool info |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 6119 Registered: Jul-06 | Damn Khae, you don't listen do you? I already told you how much power you'd get from a pair of KX1200.1s... did you think I was lying or something? |
Bronze Member Username: KhaePost Number: 80 Registered: May-07 | hahaha noo!! lol imma get those kintek hc2400 though n then a h/o alt b4 summer comes a long!!!! maybe n like 2 months or sooner!!!!! |
Silver Member Username: TornPost Number: 349 Registered: Jan-07 | Alt before that kinetik and unstrap them you clipping the crap outta them and sub, the deck even skip on usb mode... and major @ss voltage drop. Basically a ghetto comptom gangster with a strap but no bullet setup... |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 6122 Registered: Jul-06 | I told him many times that he's going to damage his equipment without an alternator so he hit me up asking how hard it was to install an alt but I wasn't on my comp but...an alt isn't too hard to install unless you have to do custom work. If it just bolts up it's a cake walk. Get an alternator before you blow something up Khae, I'm not telling you that you're going to blow sh1t because I'm an azzhole, I'm telling you because it's the truth. Get an alternator before you get any batteries. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 4401 Registered: Jul-06 | Agreed with Rob |
Gold Member Username: InsearchofbassPost Number: 7289 Registered: Jun-04 | I agree also |
Silver Member Username: Mj23dynastySome where 12 wangin o..., The Mighty J... USA Post Number: 563 Registered: Oct-07 | read up on clipping dude www.bcae1.com |
