Cerwin Vega vs. Memphis
Username: Lucky777
What is a good speaker for around $450
I have looked at some Cerwin Vega Stroker 152s and a Memphis M3MOJO15 which is better
Username: Philly306
North carolina
Post Number: 517
what type of sound are you looking for? spl(loudness) sq(quality) or sql lil of both. so you already have the amp?
we can suggest a better sub for 450.
Username: Rovin
4 10 Pioneer...
Post Number: 12470
heard a pair of 15 stroker pro last might - man that sh1t was deadly low & loud ! ....
Username: Nd4spd18
Northwest PA
Post Number: 3888
That's a nice budget for a sub. But yeah, answer phil's questions........ there are much better subs than the 2 you mentioned for that price
Username: Lucky777
what others would you suggest?
Username: Nd4spd18
Northwest PA
Post Number: 3907
What do you want?
SQ = sound quality
SPL = loud
SQL = combination of those
Username: Lucky777
SQL, or maybe a little more SPL
Username: Loudon
Post Number: 1958
rd alpha
Username: Nd4spd18
Northwest PA
Post Number: 3942
How much power do you have?
A DD 3500 series would be great, it's an SQL sub that leans toward SPL. They need ~1500 watts.
Username: Lucky777
Post Number: 7
im getting my amp after the speakers, so i can have the right amount of power put to them.
Username: Jakeyplaysbass
ASU
Post Number: 2075
stroker pros are crazy loud rovin, i agree with ya 100%.
