Dd2512 vs. Re SE
Username: Mj23dynasty
Harrisburg star city, Pistolvania USA
Post Number: 181
so far these are my two options for loudest setup without an electrical upgrade. they will be run off a kicker zx 1500.1. the dd2512 are going to run me 490 shipped for 2 12" and the SE's are like 350 shipped on ebay for 2 12" which ones will pound loudest and sound good doing it?
Username: Nd4spd18
Northwest PA
Post Number: 3989
The DD will be louder. SQ will probably be about the same, DD 2500 series have somewhat better low-end than the 3500s and 9500s.
Post Number: 185
Yo that's exactly what I'm looking for some 2 12" of those will sound right on a kicker zx 1500.1
Username: Nd4spd18
Northwest PA
Post Number: 3993
Yeah 2 of those subs would be a good match for that amp
Username: Talon01
12 audioque 2.5 144.9 ..., Pa Usa
Post Number: 337
^^^^x2
Username: 420alldaylong
Post Number: 2896
I like both but the DD2500 are little monsters.
Post Number: 186
so there are no problems with the 2512"s no spider problems or anything and can i get them for cheaper than 490 shipped anywhere?
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 5478
The 2500's will give you some amazingly punchy bass...they surprised me.
Post Number: 5479
OH...and that amp would NOT be a good match.
Its rated at 2ohm....a pair of 2500's would give you a 1ohm load.
Post Number: 187
well get me a great amp to go wit them
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1735
A RF10001bd will gave you a solid 1400RMS @ 1ohm. I have a Power Series amp and love it. I don't know if that is enough power tho??
Username: Nd4spd18
Northwest PA
Post Number: 4006
" so there are no problems with the 2512"s "
Quality problems? With DD subs? Please.
Post Number: 2898
DD=Quality DD=Quality DD=Quality DD=Quality
Username: Nd4spd18
Northwest PA
Post Number: 4012
Oh damn I forgot about those only coming in DVC 4 ohm........ thats annoying. That RF amp would be good, and theres a ton of other good amps that do that power.
Post Number: 2899
This amp would be great for those subs.
https://www.ecoustics.com/electronics/forum/car-audio/403355.html
