Breaking In Subs + Wiring
Username: Audiosaab
Potomac, MD
Post Number: 63
so if I'm getting a Dual 12" vented Subwoofer box and installing 2 12" type R 4ohm speakers into it how exactally would i wire it to the box and then, how should i wire my Hifonics Brutus 1606D mono amp to the box?....once finished how exactally do you break in a Subwoofer and if anyone knows how long does it usually take for a pair of 12" Alpine SWRS?
Username: Nd4spd18
Northwest PA
Post Number: 3977
I have never ever seen a sub damaged from not being broken in, as far as I'm concerned that is a myth until I see it proven.
I have seen many cases of subs changing sound a little bit as they are broken in as the suspension loosens up.
Username: Audiosaab
Potomac, MD
Post Number: 64
k and as for the wiring how do i get them running at 1 ohm from the amp?
Username: Johnfiac
A-ToWn, 9515 thumpin... What u bumpin?
Post Number: 3818
breaking a sub in only makes it sound better... i tossed to one of my dd9500's when i first got em..right out of the box
Username: Johnfiac
Post Number: 3819
tossed 3K**
Username: Nd4spd18
Northwest PA
Post Number: 3983
Do you mean DUAL 4 ohm?
To wire two DVC 4 ohm speakers to 1 ohm you wire everything in parallel. That is, all + to amplifier + and all - to amplifier -
Username: Audiosaab
Potomac, MD
Post Number: 65
k thanks
Username: Audiosaab
Potomac, MD
Post Number: 66
o and so how do i exactally break them in? just let them run or what?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13134
where u getting ur box from??
I have a box built for 2 type r's...that i have no need 4...
Username: Nd4spd18
Northwest PA
Post Number: 3986
You don't have to do anything. Just play them.
Username: Johnfiac
Post Number: 3825
if u want them to break in faster drive around playing some 40hz test tones or somthing LOL
Username: Audiosaab
Potomac, MD
Post Number: 67
lol killa ill be doing that anyways when i show off to people so no worries, and chauncey i havent purchased the box yet, im still looking into it, is your box sealed, vented, ported? and i need size specs as well
Username: Johnfiac
Post Number: 3829
^im almost 100% sure its going to be ported and tuned to low 30s
Username: Audiosaab
Potomac, MD
Post Number: 68
A) is that a good thing? and B) what the hell is the different between ported and vented? I thought vented was the large slot thing on the side and ported were the circles but mabye that a b.p box im thinking of....
Username: Nd4spd18
Northwest PA
Post Number: 3988
vented = ported they are the same thing.
What you are thinking of is a slot port vs. a round port.
Username: N2audio
Lawrence, Ks USA
Post Number: 1412
I'm with M.S. on break in.
It belongs in the audio mythology 101 category.
Subs and speakers do "break in", and they do it regardless of what signal they're reproducing.
Slight changes in some parameters of the speaker can be measured before vs after break in, but resulting effects on what we hear are somewhere between subjective and non-existant.
Install them, listen to them, be happy.
