Is this a good deal for dynamat extreme
Username: Insearchofbass
Post Number: 6808
100 bucks for a dynamat extreme bulk pack off of a acquaintance
Username: The_image_dynamic
San Diego
Post Number: 2952
That pack goes for around $125 online if you shop around but it is VERY heavy and shipping is a b!tch, so yeah.... good deal for some quality dampening. There are many other options (Raamat, Second Skin, Cascade) that are either cheaper and/or better, but Xtreme is some good stuff.
Read up on it before you commit:
http://www.sounddeadenershowdown.com/
Post Number: 6810
ok thanks Brad
Username: Frkkevin
Post Number: 3875
Peal-N-Seal @ Lowes .. $14 a roll .. 6" x 24' .. FTW
San Diego
Post Number: 2957
^^ Agreed. If you are going to go with a foil backed asphalt product, it is impossible to beat Peal N Seal. In fact (and they were hesitant to admit it until side-by-side tests confirmed it) the original eDead from Elemental Designs was EXACTLY the same as Peal N Seal. If you are on a very tight budget, multiple layers (3+) of Peal N Seal applied with a heat gun works well.
Username: Frkkevin
Post Number: 3879
even a hairdryer is sufficient enough if you don't have a heatgun :-)
Username: Jakeyplaysbass
ASU
Post Number: 2019
easy job if you have a heatgun and a good roller.
Username: Hdubb
Team Revolution
Post Number: 2697
dynamat or any buytl mat product is a good investment. im telling you guys make a friend at best buy andbuy it through them. they get it dirt cheap. (if a bb is in your area)
Username: Jkidder
Gunshine , State Flawda
Post Number: 2286
or make a friend who has a friend at best buy
Post Number: 6835
He bought the dynamat extreme. It will be intresting to see how much if any difference it makes on our spl meter. Ill post the results whenever it is done and tested.
