Sound deadening
Username: Evoixmr
Post Number: 122
what are some good sound deadeners?
Username: Bernymac
BME
Post Number: 3290
I run edead v1se^2 something like that. worked great for me. For the floor I would do peel n seal or w/e its called. For vertical surfaces, the edead should be fine. For the roof, I would look into some rammat. Thats just me.
Username: Evoixmr
Post Number: 123
Is Edead a butyl, asphalt or mix. I've heard that some sound deadeners make your car smell like asphalt when its hot outside.
Has anyone used second skin?
