Alpine Type X or MTX 9500?
Username: Mateao234
Post Number: 52
debating on what to buy next, if you have any suggestions for subs in the same price range that are better that are easy to get, i am open to any suggestions
Username: Rovin
4 10 Pioneer...
Post Number: 12047
havent used neither but from what i read every1 says type x is more SQ where as the mtx = spl ......
Username: 04redmach1
Columbus, GA USA
Post Number: 1258
Ya, those subs are different. What kind of budget do you have for sub? What amp are you running? Feel free to email me.
Kevin
lowhz01@yahoo.com
Username: Mateao234
Post Number: 53
same as ive heard, the mtx is massive, like 75 lbs and comes in a 15 as the type x doesnt, at least that i see, just checkin ebay
Username: Mateao234
Post Number: 54
not sure, ive got a crap amp atm, a soundstorm lol, but im upgrading everything ive got. plan on spending around 300 per sub, so i have enough for an amp box and im going to have to upgrade the big three most likely if im pushing alot of power
Username: Mateao234
Post Number: 55
but im gettin offline so leave messages ill be on tomorrow
Username: Big_edge_head
Milwaukee, Wisconsin USA
Post Number: 519
ive heard a mtx 9500, 1000wrms it does 145db in the mtx sledge hammer box
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 1...
Post Number: 5184
Forget about the MTX 9500!
*Note*---this is coming from an MTX DEALER!!! (me)
We are dropping MTX...the mtx 9500 is a waste, and they just dont stand up to any of the hype. (That and MTX fvkt our shop over)
But if you are looking into MTX subs, try the 8500...it is by far a better sub for the $. They sound better and are much more efficient.
Yes the mtx9500 will handle alot of power, I ran one daily on an memphis mojo (2kw), but it is VERY inefficient. Its a huge sub w/ HUGE moving mass and a BS heat-sink in the gap. Total was of materials IMO.
Username: 420alldaylong
Post Number: 2565
matt lennon
Take a look at these companys.
AudioQue
Ascendant Audio
Ficaraudio
Revolution Design
Treo Engineering( great subs but bad service)
Digital Design
Resonant Engineering
Eclipse
Soundsplinter
T3 Audio
Stereo Integrity
Incriminator Audio
Thats all I can think of right now but I'm sure others will add to the list.
Columbus, GA USA
Post Number: 1262
Matt, if you are looking around $300 a sub, you can grab a pair of Rd Audio Alpha V1 D4 12's for $500, and either a 1750.1, or 3250.1 to match. Depends on how much effort you want to put into your electrical system.
Kevin
lowhz01@yahoo.com
Username: Mateao234
Post Number: 56
thanks for the input guys
Username: Mateao234
Post Number: 57
http://cgi.ebay.com/TREO-ENGINEERING-HOTBOX12-12-TSX-SUB-BOX-2-TSX12-44_W0QQitem Z150155403727QQihZ005QQcategoryZ32823QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
So, this would be a good buy? and then i wouldnt have to upgrade my alternator or anything because it wouldnt be pulling a whole lot of power.
