kragan Unregistered guest | Anyone know if only connecting 1 voice coil of a DVC sub would damage the sub? Thanks |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 2983 Registered: Dec-03 | yes and yes, it will. |
trickfly04 Unregistered guest | how so glasswolf? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3022 Registered: Dec-03 | a DVC sub needs the same power to both coils for the speaker to move back and forth properly within the magnet structure. you'll trash the coils powering only one coil. bcae1.com should have a diagram of a DVC sub. look at how its constructed. the dual coils are strictly there to be wired in series or parallel to offer various loads to the amp. |
Anonymous | i have a 15 inch sub that i blew. it's a dvc 4 ohm subwoofer. one of the coils went out, and so i just bridged one of the coils of the sub to an amp stable at 4 ohms. this wouldn't matter because the other coil is fried already right? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 3034 Registered: Dec-03 | eh, I guess. www.circuitshop.com or similar places can rebuild the sub for you a lot cheaper than it'd be to replace it if the sub is worth much. |
