Bronze Member Username: IgotkingkongindatrunkPost Number: 37 Registered: May-07 | i have an optima red cap under the hood of my truck and was wondering if it will push an 800 watt amp and 2 3000 watt amps? |
Gold Member Username: CtmikeCt. Post Number: 4942 Registered: Feb-06 | post the rms of those amps, not peak or max ratings. and i'd be more worried about the size of the alt. |
Bronze Member Username: IgotkingkongindatrunkPost Number: 38 Registered: May-07 | the alt is stock haha because im running the 800 with the 3000 watt but i want another 3000 watt. and my lights dim biiiiig time |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1504 Registered: Jun-06 | hecks no!!! You are gonna need major electrical upgrades. Were talking a very high amperage H/O alt. I'm thinking at least 3 batteries. And many runs of 1/0 wire. Also dont forget the big 3 |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1505 Registered: Jun-06 | "the alt is stock haha because im running the 800 with the 3000 watt but i want another 3000 watt. and my lights dim biiiiig time" How many batteries have you killed? lol |
Bronze Member Username: IgotkingkongindatrunkPost Number: 39 Registered: May-07 | i havent killed any batteries yet im running four twelves off that 3000 watt amp lol |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1506 Registered: Jun-06 | What amp you got? |
Bronze Member Username: IgotkingkongindatrunkPost Number: 40 Registered: May-07 | PT 3000 digital 1ohm |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1507 Registered: Jun-06 | Ive never heard of it. What does the PT stand for? |
New member Username: CaliloonMoreno valley, CA Us Post Number: 3 Registered: Aug-07 | performance teknique |
Gold Member Username: Naledge503Http://com4.runboard.c... Post Number: 1541 Registered: Jun-06 | http://cgi.ebay.com/3000-WATT-CLASS-D-MONOBLOCK-AMP-MONO-CAR-AMPLIFIER_W0QQitemZ 170138709778QQihZ007QQcategoryZ64570QQcmdZViewItem This one? NEVER go off of max ratings always go off rms ratings. With everything you are running and want to add more....you should start thinking about and H/O alt. |
